cant get my s2 to star ive tried everything a new coil. leads. dissy. fuel pump. metering head but no luck yet the pumps coming on and im gettting fuel at the metering head just not out of the injector. if i leave it over night and go and try start it it will fire once than nothing anyone any ideas
I had the same problem with mine. in my case i went through 4 metering units and finaly i found 1 that was alright. seeing there all 17 years old OR older there proberly all due to fuck up at some point. when it happend to me it cooked my head for about 3 months trying different things and put a dent in the walet but thats what my problem was hope this might be some help to you coz it done my head in
take the spark plugs out, and crank it over, wait till you can smell fuel in the bores, then put plugs back in, and crank it over, See if it starts then.
i recon you got an air lock in your fuel line, if you change a mettering unit or like i did, took mine of to clean it out etc. You will 99% of the time have air in the fuel lines. The way above will let the air be pushed out of the hole where the plug normaly is.
