escos question
Old Jun 16, 2007 | 05:54 PM
dake205's Avatar
dake205
Default escos question
hi quick question i dont know a thing about 4x4 and recently broke the passenger side driveshaft on my escos now i ve replaced it i need help with replacing any lost fluids i.e. is it differential or gearbox how much and where to
Old Jun 16, 2007 | 06:18 PM
escossie560's Avatar
escossie560
Should not have lost to much of any fluids but its worth checking fill plug for diff is a large torques bolt about halfway up the diff fill it until it starts dribbling back out it wont take much, before you try and undo it give it a good smack with a hammer or you will round it off.
Did you pop the drive shaft out of the end ,if you did check the engine mount as they are prone to failing and eating driveshafts as the engine lifts.
Old Jun 16, 2007 | 07:03 PM
adamski frst's Avatar
adamski frst
From: brum/shropshire drives:- frst / escort cossie
i have the same problem atm, unsure whats causing mine so doing lots to reslove it, BUT you will have not lost any fluids but as said check anyway for peace of mind... you only lose fluids if there is a problem diff side
Old Jun 16, 2007 | 07:09 PM
dake205's Avatar
dake205
thanks guys didnt think i had lost any but just thought it would be good to check and im not to sure about the diff setup will check tomorrow thanks
Old Jun 17, 2007 | 04:35 PM
S3an's Avatar
S3an
have you checked your engine mounts as its always the near side mount that callopses.
Old Jun 18, 2007 | 09:26 AM
dake205's Avatar
dake205
engine mounts are fine mate thanks just a simple bit of mistreatment on a b road
gcfcos
59
Oct 6, 2015 05:04 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
