cam shaft removal on erst
i no it can be done in place but was just wondering whats the easyest method
remove o/s engine mount and jack engine up? or does the gearbox mount need to come off too, cheeRS
No need to remove any engine mounts bud.
Remove cam belt, cam pulley,
Take off your rocker cover and remove rockers,
Take off your dizzy, you might want to mark it first to be somewhere near, but if your changing the spec of your cam, you may need to alter the ign timing anyway.
With the dizzy off, the camshaft should come through the hole, through the gearbox side.
HTH
HTH
Fudgey
Sep 17, 2015 01:06 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
grishenko45
Sep 9, 2015 12:58 PM
