wiring in ERST in place of CVH (mk5)
lots of questions in here so if you cant be arsed reading then click off now lol, although any help at all would be very much appreciated!
ive fitted an ERST lump into my mk5 cab but i cant get the thing to start.
i think i might be doing it the hard way tho..
im trying to use both looms at once, ive got the mk4 loom wired up to then engine but instead of wiring everything from that i thought it would be easier for the time being if i just wired the 2 ignition plugs up together so that turning the key on the mk5 loom was effectively doing the same on the mk4 loom. i kept the mk5 starting and charging circuits as i assume they are the same?
now the cars pumping fuel (im still using the stnadard pump atm, will be buying an uprated pump when ive got the engine starting) and theres a spark but its not wanting to start although it is turning over.
should i completely remove the mk5 loom from ANYTHING to do with starting ie mk4 wires for fuel pump, ignition, spark, starter motor?
will i have to make the mk5 loom go live at all just to get it to run?
ive tried to keep my mk5 sensors like the temp sensor, simply to save me from having to try and rewire my clocks but im not sure exactly what plugs i should keep.
any help really would be much appreciated!
cheers
cheers
i know how u feel fella. try sending a PM to safechav. He very good on electrics and looms. He helped me out loads. Top bloke
i got few ideas but i personally will prob be wrong. give him a try. He on most nights so u should get reply soon. tell him i forwarded you
Hi mate,
I've just finished doing something very similar, i dropped a S2 RST lump into my mk5 (albeit tintop). I think you'll find it easier to find any problems if you pull the mk4 loom apart and just keep the parts that run the engine. On mine i ended up splicing the RST loom parts onto the mk5 engine loom connector so i can take the whole lot out.
Bearing in mind all the engine needs to run it is power to the ecus and fuel pump (and some sensors and stuff) and a cranking feed it ends up being quite a small loom.
MazakMan
MazakMan
Originally Posted by MazakMan
Hi mate,
MazakMan
MazakMan
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
