mk4 escort
just got a mk4 escort 1.3 as a run about. got it for £75, f reg, 85000miles, black and not alot of rust oh yeah and 10months tax. neway. u put it in gear and lift slowly off the clutch there is a whining noise, what do u reckon ? clutch plate, or bearing, or something else. nehelp would be apresiated
ifankoo
ifankoo
Not to sure mate, but if you do a search for Gearbox man on the internet and get his number, then give him a call, he would most likely tell you, he does alot of modded fords, so mention that he was recommended from the passion for site and pick his brain.
Is it a three door or 5 door, 3 door would mean you have a top little car to start modding.
Just read your first post again and you say its only when the clutch starts to engage.
That sounds more like perhaps the plate is wearing down to the rivets.
Does it feel like the clutch is about to give up?
When you sit there with the engine running and your foot fully on the clutch does it whine then?
Also when in neatral and you lift off the clutch does it do it then? Or only when a gear is selected?
Dr. Ickxs
Sep 15, 2015 10:15 PM
chris m1
Sep 7, 2015 08:02 PM
