lamba sensor (electrical) question
Old Jun 13, 2007 | 11:15 AM
b_kennedy's Avatar
b_kennedy
Default lamba sensor (electrical) question
A cosworth lamba sensor has 4 wires (if u dont know)
I got 2 whites for power and earth. And I've got a black and a grey.
Does anyone know which is earth and which is signal. I would gather black is earth but I was told it was signal so i though i'd ask the pro's
Old Jun 13, 2007 | 11:19 AM
Graceland's Avatar
Graceland
Team HOTHOT!
All the Cossie Lamda sensors I have seen only have 3 wires - Red, Black and Grey/white
Old Jun 13, 2007 | 11:21 AM
b_kennedy's Avatar
b_kennedy
thats f**ked it then. Was told it was a cossie one. Its definately a ford lamba cos it marked.
Old Jun 13, 2007 | 11:59 AM
The two whites are for the HEATER, ie one is live one is earth(heater only)
The black is SIGNAL WIRE, the Grey is earth.
This shows it to be a ZIRCONIA SENSOR.
Ford also use another four wire which is BLACK, RED, YELLOW, WHITE, but these are 0-5 VOLTS, where as your one is 0.1-0.9 VOLTS.
hope this helps.
Old Jun 13, 2007 | 12:13 PM
b_kennedy's Avatar
b_kennedy
perfect. thats a few times you helped me out tabetha Thanks very much
Old Jun 13, 2007 | 04:53 PM
No probs glad to get one right for once!!
Old Jun 13, 2007 | 04:55 PM
ECU Monitor Enthusiast
tabetha,
You worry too much matey
DixieTheKid
11
Jun 6, 2020 11:20 AM
Kam B
Sep 24, 2015 10:40 AM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
