where are the zetec timing marks?
Old Jun 12, 2007 | 08:55 PM
fonfe123's Avatar
fonfe123
Default where are the zetec timing marks?
sorry i know sounds like a really stupid question but i cant find it anywhere!?
where are the timing marks for the crankshaft to be at TDC?
its driving me
Old Jun 12, 2007 | 10:23 PM
SafeChav's Avatar
SafeChav
There aren't any..........another money saving tip brought to you by Ford.
If you've already taken the belt off you're going to be in a spot of bother.
Theres a timing kit you need to buy in order to refit the new belt properly and accurately
Wardy257's Avatar
Wardy257
Im not sure there are any. Are you trying to change cams?
Old Jun 13, 2007 | 06:11 AM
It's a piece of piss, PIN goes in hole uncovered by removal of 10mm bolt, to line crank up at TDC, them 8mm rod or flat bar in back of cams, the slot is OFFSET so will only go in the correct way.
The pin for the crank is a precise length so that a flat section on the web of the crank contacts the end of the pin so it can go no further and this is TDC.
Old Jun 13, 2007 | 10:33 AM
SafeChav's Avatar
SafeChav
it may a piece of piss with the timing kit but from what hes said above he doesnt have one?!
Old Jun 13, 2007 | 11:49 AM
You need to buy the kit or pin at least, as it is a precise length, you can lock the cams with 8mm flat bar, drill bits, bolts etc, so loong as it is 8mm it will fit snugly enough.
I don't remember there being ANY timing marks at all, only done 3/4 though so some may be different, but there were defo none on the ones I did.
Old Jun 13, 2007 | 02:27 PM
SafeChav's Avatar
SafeChav
are you for real or what you've basically said what i posted above now?!
Billy_RS
16
Oct 11, 2025 09:41 PM
MK Motorsport Matt
75
Nov 15, 2015 11:22 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
