ive got a 89 rs turbo, its had loads of problems running lately, it was running fine last sunday afternoon, then decided to start misifring and then cut out, the fuel pump relay had some dodgy wiring and the relay ws burnt out so got it fixed along with a new rely straight from ford, but he problem still exists. The relay works fine the fuel pump primes and the car turns over, nearly starts then doesnt, you can smell fuel and the spark plugs are full of carbon. any suggestions before i starts replecing things???
when it first started happening the car was hot because it had been running, but ever since its been cold, it does get going sometimes if you pump the accelerator but only for a second
ive unplugged the CSV, ive got fuel to the distributer but when i remove the fuel line for the injectors from the distributer theres no fuel coming out???
