1.8 to 2L zetec conversion
Old Jun 9, 2007 | 07:18 PM
rigwrecker's Avatar
rigwrecker
Default 1.8 to 2L zetec conversion
hi got an orion 1.8 zetec just have a couple off questions before i put the 2L in can i use the 2L ecu and inlet manifold and keep the 1.8 loom or do i need to put the 2L loom in place of the 1.8 also do i need to use the fly wheel, sump and pickup pipe from the 1.8? any other info would be greatly recieved cheers adam
Old Jun 9, 2007 | 10:10 PM
Wardy257's Avatar
Wardy257
There is little point in swapping engines as the 1.8 can produce very similar power to the 2.0lt cheapily. Only if you get above 200 bhp is the swap worth it.
Old Jun 10, 2007 | 01:13 PM
rigwrecker's Avatar
rigwrecker
1.8 is seized and have a 2L and loom lyin in my garage thats why am changin it
Old Jun 10, 2007 | 11:08 PM
rigwrecker's Avatar
rigwrecker
any info peeps
Old Jun 12, 2007 | 07:31 PM
Wardy257's Avatar
Wardy257
For a focus?
Old Jun 12, 2007 | 07:58 PM
rigwrecker's Avatar
rigwrecker
eh?
Old Jun 12, 2007 | 10:25 PM
Wardy257's Avatar
Wardy257
Originally Posted by rigwrecker
eh?
Sorry, got confused by your avtar.
You need the sump, inlet, water pump and (not essential) flywheel from your 1.8. Swap it all over then compare the wiring diagrams of the 2 ECU to see if you need to move pins about. If the 2.0 ECU has PATS you will need to find one the hasn't got PATs.
Old Jun 12, 2007 | 10:30 PM
SafeChav's Avatar
SafeChav
You'll probably find you can't just plug the 2.0 ECU in.
All depends on whether the PATS and EDIS are external or not.
Obviously anything is possibly, where there is a will there is a way but just dont expect to plug it in and fire it up.
Old Jun 13, 2007 | 04:12 PM
rigwrecker's Avatar
rigwrecker
cheers lads hopin to have a go at it this weekend weather permitting
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
