Car Detailing in Berkshire.
Old Jun 9, 2007 | 06:07 PM
ECOS95's Avatar
ECOS95
Default Car Detailing in Berkshire.
Can anyone recommend a good place in Berkshire to take the car to to be detailed ??
Cheers.
Chris.
Old Jun 13, 2007 | 01:18 PM
EssexBoyRacer's Avatar
EssexBoyRacer
There's a fella on here AndyH_ZS, He's done my partners previous and current cars and done a fantasic job at an exceptionally resonable rate!
Also
I know of an enthusiast based in reading. I've seen his work on posted on forums and it looks ok!
Robbed his post from www.e36coupe.co.uk...
Originally Posted by Breezy
had a black Honda S2000 to keep me busy over the weekend with a detail which i had booked from a mate a few weeks ago, here is the car on arrival
quite a lot of dust & dirt on the car so to get things going I foamed it up with my karcher foam gun and used chemical guys maxi suds 2, I let this dwell for 5 minutes then rinsed down with the karcher.
I then washed the car using the 2 bucket method with a lambswool washmitt & my chemical guys buckets both with grit guards.
after this I tried the car using my sonus ultimate drying towel and the swirls could cleary be seen in the sunlight
I then masked the car up and put her in the garage for claying & polishing
I clayed the whole car using sonus green clay, and this is what it looked like after the front wing
I then masked off a section of the boot to see what polish & pad combo I would need, after doing a bit of research I was aware Honda paint was fairly soft so as always started with the least abbrasive polish and
worked my way up.
First I tried Menzerna PO85RD on a "6 Blue finishing pad and this didnt really remove many of the defects, so I then stepped up to PO106FF on a white polishing pad and this removed around 70% of the defects so to improve
this I then stepped up to Intesive Polish Po91L on a white polishing pad following up with Po85RD on a blue finishing pad and I was happy with this result
BEFORE
50:50 after P106FF
50:50 after PO91L & PO85RD
So with my chosen pad & polish combo I proceeded to polish the wholecar using my porter cable and even found that I was getting some slight micromarring after using the Intesive polish however this was soon rectified with the PO85RD & the blue finishing pad.
I then applied a coat of Chemical Guys Blitz sealant to the car and the following day applied o coat of harly carnuba wax and this gave a really nice clear shine on the black car, rubber seals & tyres dressed with chemical guys new look trim gel and glass and lights cleaned with autoglym glass polish.
I then went round the car with chemical guys synthetic quick detailer to remove any polish & dust, the exhaust was also cleaned & polished with autosol.
So here are the pics of the finished result...
Exhaust before
Exhaust after
Some shots in the Sun
the owner was very happy with the results 8)
Old Jun 13, 2007 | 01:50 PM
scortgti's Avatar
scortgti
that s2000 looks amazing!!!
Old Jun 14, 2007 | 06:50 PM
Brian's Avatar
Brian
Brian
Old Jun 16, 2007 | 04:06 PM
littleknocks's Avatar
littleknocks
get the mop out its easier lol
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 8, 2015 07:12 AM
onionlover
Aug 6, 2015 03:20 PM
