draining the fuel tank
Old Jun 6, 2007 | 01:18 PM
saph in dorset's Avatar
saph in dorset
Default draining the fuel tank
hi guys
what would be the best way to drain the tank. i have the pump which you can put into the tank and it sucks it out. could i also use the in tank pump to help aswell.
is there any other ways apart from dropping the tank.
thanks
adam
Old Jun 6, 2007 | 01:37 PM
jon@work's Avatar
jon@work
jack the car up and undo the 15mm ID pipe between the tank and the pump - don't get fuel in your eyes, though - it stings
Old Jun 6, 2007 | 01:55 PM
saph in dorset
thanks for that jon.
i take it the pipe in near the fuel tank under the car.
Old Jun 6, 2007 | 03:08 PM
jon@work's Avatar
jon@work
you'll see the fuel pump and fuel tank if you have a look under the car - then the pipe'll be obvious
timsrs
Nov 13, 2018 11:48 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
mpilk
Sep 27, 2015 09:21 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
