draining the fuel tank
hi guys
what would be the best way to drain the tank. i have the pump which you can put into the tank and it sucks it out. could i also use the in tank pump to help aswell. is there any other ways apart from dropping the tank. thanks adam |
jack the car up and undo the 15mm ID pipe between the tank and the pump - don't get fuel in your eyes, though - it stings
thanks for that jon.
i take it the pipe in near the fuel tank under the car. |
you'll see the fuel pump and fuel tank if you have a look under the car - then the pipe'll be obvious
© 2024 MH Sub I, LLC dba Internet Brands
