esc cos technical
gents ive been having a real bad idle, hunting up and down, running real crap
now I pulled the hose of the inlet manifold the one that goes to the map sensor and instantly it starts running perfect ?
what is that indicating please ?
Thanks Glen
Thanks Glen
Originally Posted by Spiky
the blue water temperature sensor or TPS
have got a new blue temp sensor here mate, will get that in asap, the TPS was working perfect prior to fitting my new motor, im strugglin with this one
hmmm, it is a 3 bar map sensor isn't it, and not the std escos 2.5 bar one... if the chip is expecting to see x.x volts at idle and is actually getting y.x volts until you take the pipe off and then it just happens to read x.x by fluke, ?
has it got a vent to atmosphere dump valve?
