engine cuts out?!
Old Jun 1, 2007 | 05:08 PM
benreader's Avatar
benreader
Default engine cuts out?!
hi guys, went for a drive lastnight and all was fine, after about an hour the car just cut out. all electrics remained intact but the engine simply died, no shudders like a stall or fuel shortage, just quietly stopped turning over?
not quite sure what it could be, any ideas?
Old Jun 1, 2007 | 10:56 PM
djmillsy's Avatar
djmillsy
Fife Radge
petrol?
djmillsy's Avatar
djmillsy
Fife Radge
nah just kidding getting spark
Old Jun 2, 2007 | 06:30 AM
It died, but what was it like when you tried to restart it ?
You need to determine if it is electrical or fuel, ie are you getting a spark firstly.
Old Jun 6, 2007 | 12:56 PM
benreader's Avatar
benreader
just switched the ignition on and off and it came back on straight away, the car is a bit of a slow starter anyway, think the battery is a bit old.
Old Jun 6, 2007 | 01:17 PM
SafeChav's Avatar
SafeChav
so is it running again now
Old Jun 6, 2007 | 08:44 PM
benreader's Avatar
benreader
yeah mate the car runs fine, when it has cut out you just have to turn ignition off and then on again and it fires up, just not sure whats causing it to cut out in the first place though. its only just started last week, done it 3 times so far.
car was at msd last week, was chipped, new cam, increased boost to 18psi and had an oil change if that gives any clues?
Old Jun 7, 2007 | 12:10 AM
SafeChav's Avatar
SafeChav
you need to establish if its losing fuel or spark
Old Jun 7, 2007 | 10:42 AM
benreader's Avatar
benreader
how do you mean mate, its not leaking fuel from what i can tell, how would i determine if its losing fuel or spark?
Old Jun 7, 2007 | 11:35 AM
SafeChav's Avatar
SafeChav
for it to cut out you're either losing ignition spark or fuel into the cylinders, so you need to fault find and see which of the two is being lost, you will be just guessing if don't try and find the fault logically.
Old Jun 7, 2007 | 07:23 PM
benreader's Avatar
benreader
so how do i actually test these problems, thing is its pretty inconsistent at the mo as its only just started so its not like it does it everytime i run the car?
Old Jun 7, 2007 | 07:50 PM
SafeChav's Avatar
SafeChav
spare spark plug in a HT lead to test for spark, testing for fuel will be a bit more tricky.
Old Jun 7, 2007 | 11:28 PM
stevetinks's Avatar
stevetinks
this may seem a bit daft but if its only happened few and far between, is there the off chance that you knocked the key with your knee
3drRich
Sep 13, 2015 07:32 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Bailes1992
Aug 16, 2015 07:14 PM
track.focus'd
Aug 12, 2015 05:53 PM
