Idle Control Valve
Old May 30, 2007 | 07:26 PM
jpbaginski's Avatar
jpbaginski
Default Idle Control Valve
Has anyone cleaned there idle control valve on there cosworth.
Did you clean the valve when out with carb cleaner?
Got a problem with cold running at the moment,getting a slight mis and some surgeing when cold but when warmed up car is fine.
any help would be gratfull.
Thanks.
Old May 30, 2007 | 07:29 PM
ECOS95's Avatar
ECOS95
Did mine with carb cleaner, didn't do much to fix my issue unfortunatley. Had to buy a new ISCV in the end.
Old May 30, 2007 | 07:33 PM
jpbaginski's Avatar
jpbaginski
How much for a new one?
Old May 30, 2007 | 07:36 PM
ECOS95's Avatar
ECOS95
Mine was £50 for my ST Escort from a guy on here. Not sure how much from Ford but I do remember someone saying around the £100 mark.
Give the carb cleaner ago, lots of crap will come out and its a cheap option.
Just leave it to dry which doesn't take long.I used a small paint brush to clean inside it.Don't forget to buy a new Gasket as mine was knackered after I took it off.
Old May 30, 2007 | 07:39 PM
jpbaginski's Avatar
jpbaginski
I think that is what I will do first get the cleaner out?
Old May 30, 2007 | 08:44 PM
Carb cleaner then spray libberally with SILICONE POLISH.
Old May 30, 2007 | 08:47 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
i have one for sale is VVGC as i bought 2 for anti lag. want £70 posted
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
