Tracking/Wheel Alignment
Old May 30, 2007 | 11:56 AM
smudge_lad's Avatar
smudge_lad
Default Tracking/Wheel Alignment
Need to get this done so phoned up about it today. The guy was asking whether my car was lowered and had big wheels, as they might not be able to get the tools in to do the job
Anyone else have problems? Will I need to swap the springs to get it raised a bit, get the tracking done, then lower it again?
Keir
Old May 30, 2007 | 11:58 AM
SafeChav's Avatar
SafeChav
some places can't accomodate lowered cars because of the systems they use.
Have you got a Pro Tyre near you? Never had any problems with them
Old May 30, 2007 | 12:45 PM
iansoutham's Avatar
iansoutham
OCD Victim
Default Re: Tracking/Wheel Alignment
Keir
If you swapped springs before and after, then you would invalidate the point of doing the tracking. It will change as soon as you change anything.
It sounds like the place is using the type of equipment where you attach it to the side of the wheel on the rim edge and use a light-gauge, not the better type with laser alignment (like Elite in Essex for example).
My advise, take it somewhere that understands lowered vehicles and the different settings you need accordingly.
steerfromdarear
28
Jan 29, 2016 06:14 PM
YODI
Aug 30, 2015 01:12 PM
COSSIE 1
Jan 27, 2006 04:22 PM
mxquattro
Ford Escort RS Cosworth
Jun 22, 2005 09:11 PM
foreigneRS
Technical essay Archives
Jul 20, 2004 11:06 AM
