just cant find reley
Old May 29, 2007 | 09:37 PM
morrison's Avatar
morrison
Default just cant find reley
okay been told that fuel reley is under dash(drivers side)and its a pinky colour?i cant find 1 like this?i only have 4,1 is green the second is light blue the third is dark blue and the fourth is green please help as i cant get fuel 2 my engine but the fuel pump still primes
Old May 29, 2007 | 09:49 PM
daveselwood's Avatar
daveselwood
Default relay
series 1 or series 2
Old May 29, 2007 | 09:53 PM
morrison's Avatar
morrison
s2
Old May 29, 2007 | 09:54 PM
daveselwood
Default series 2
its in the fuse box
Old May 29, 2007 | 10:03 PM
morrison's Avatar
morrison
okay cool stupid me what colour is it
Old May 29, 2007 | 10:07 PM
daveselwood
Default relay
i cant remember
Old May 29, 2007 | 10:13 PM
morrison's Avatar
morrison
okay cool coz just finished a xr3i turbo conversion but it wont start it sounds like it wants 2 but doesnt.i tested the plugs and they are all ok.i took the fuel pipe of 2 c if it was getting fuel and it is,then i took the pipes of the distributer 2 the injector but no fuel coming through (also sound like its misfiring
Old May 29, 2007 | 10:20 PM
daveselwood
Default fuel
just follow the fuel system and see how far the fuel goes,perhaps its your metering unit,fuel filter or no resistance at the injectors or ecu not telling the injectors to inject
Old May 30, 2007 | 12:59 AM
SafeChav's Avatar
SafeChav
WHAT THE FUCKKKKKK
Since when has a S2 fuel pump relay been in the fuse box??????
The relay has probably been changed and isn't pink anymore (i have some black ones)
It will be the tallest relay out of the lot, and SHOULD be in a pink relay holder.
Old May 30, 2007 | 02:41 PM
morrison's Avatar
morrison
THATS WHAT I AM SAYING I CANT FIND A PINKY RELAY HOLDER JUST THE ONES I SAYS,I ONLY HAVE 4
Old May 30, 2007 | 02:43 PM
morrison's Avatar
morrison
also does the fuel pump prime without a relay?
Old May 30, 2007 | 03:02 PM
SafeChav's Avatar
SafeChav
Fuel pump wont work without a relay, not like that anyway.
Get me a picture of the relays up there
Old May 30, 2007 | 03:19 PM
morrison's Avatar
morrison
OKAY I WILL GET 1 FOR YOU TONIGHT I THINK THIS IS THE PROBLEM THE CAR SOUNDS LIKE IT WANTS 2 START BUT ISNT FIRING UP PSTHANKS FOR THE HELP
Old May 30, 2007 | 06:48 PM
morrison's Avatar
morrison
SAVECHAV what do i use to make the image smaller?you told me it last time thanks?
Old May 30, 2007 | 07:13 PM
morrison's Avatar
morrison
Old May 30, 2007 | 07:16 PM
morrison's Avatar
morrison
Default [url=http://www.integration.avatarimage.net/][img]http://www
Old May 30, 2007 | 07:18 PM
morrison's Avatar
morrison
Old May 30, 2007 | 07:21 PM
morrison's Avatar
morrison
Old May 30, 2007 | 08:42 PM
RS 5tu's Avatar
RS 5tu
not sure of the black? maybe fuel relay 80% sure
others are heated front screen, e/w and c/l
trace the wire back take of the side trim and do the wires match?
Old May 30, 2007 | 11:35 PM
SafeChav's Avatar
SafeChav
What did i say
its the black one Holder is more purple than pink though so thats where the confusion has come from
Old May 31, 2007 | 08:30 AM
morrison's Avatar
morrison
thanks your right just wanted to make sure there was 1 coz when i start the car it sounds like its wanting to start but dont,its like its trying to fire
Old May 31, 2007 | 09:35 AM
SafeChav's Avatar
SafeChav
Have you got the dash out? Whats that wiring plug hanging there?
Old May 31, 2007 | 10:06 AM
morrison's Avatar
morrison
yeah i have the dash out i dont know what this plug if off?
Old May 31, 2007 | 10:08 AM
morrison's Avatar
morrison
is there another part of the loom that clips onto this that i dont have???
Old May 31, 2007 | 10:09 AM
morrison's Avatar
morrison
do you want another pic of this?
Old May 31, 2007 | 10:12 AM
SafeChav's Avatar
SafeChav
duno, if you have the dash out it could well be the electric mirror switch plug.
Old May 31, 2007 | 10:16 AM
morrison's Avatar
morrison
okay cool this is the only wire behind the dash not plugd in yeah,just cant get the thing 2 fire up,there is a spark and its getting fuel 2 the fuel filter(can i check the injectors to c if they are getting fuel?)or am i been stupid thanks for your help
Old May 31, 2007 | 10:22 AM
SafeChav's Avatar
SafeChav
You sure you haven't got a pipe off somewhere?
or the oil filler cap? Oil dipstick?
Old May 31, 2007 | 10:27 AM
morrison's Avatar
morrison
im like 90% sure but i will double check just to make sure,if there was an air leak would it misfire when trying to start?coz it sounds like it when starting
Old May 31, 2007 | 10:30 AM
SafeChav's Avatar
SafeChav
air leaks may stop it from starting because the flap won't move properly when you crank, meaning its not getting enough fuel.
Have you pulled that cold start injector plug off yet
Old May 31, 2007 | 10:32 AM
morrison's Avatar
morrison
no i havnt is that the blue plug at the back
morrison's Avatar
morrison
of the inlet
Old May 31, 2007 | 10:43 AM
SafeChav's Avatar
SafeChav
well stop faffing about and get it off
Old May 31, 2007 | 11:29 AM
morrison's Avatar
morrison
ok no luck just took it off just sounds the same
Old May 31, 2007 | 11:31 AM
SafeChav's Avatar
SafeChav
check and see if the flap bobs up and down when you crank the engine over then
Old May 31, 2007 | 11:56 AM
morrison's Avatar
morrison
okay just had a look and it does
Old May 31, 2007 | 11:57 AM
morrison's Avatar
morrison
yeah it does bop up and down
Old May 31, 2007 | 11:59 AM
SafeChav's Avatar
SafeChav
hmmmmmmmmmmm.
Have you had the plugs out recently? They could be fouled up from all the starting attempts
Old May 31, 2007 | 12:10 PM
morrison's Avatar
morrison
yeah they were black but cleaned them up they are all sparking,im lost now
Old May 31, 2007 | 12:11 PM
morrison's Avatar
morrison
is there any way i can test 2 see if fuel is getting to the injectors?
