Bleed nipples
Old May 29, 2007 | 01:48 PM
muffster's Avatar
muffster
Default Bleed nipples
Hello guys.
Does anyone know how to remove brake bleed nipples which have sheared off. Mine have sheared on the front caliper of my cossie. Is their a way to remove them without buggering the threads up?
I cant bleed me brakes properly!!!
Any advice would be great.
Thanks.
Muffster.
Old May 29, 2007 | 03:11 PM
Barry R's Avatar
Barry R
A tap & die kit should do the trick
Old May 29, 2007 | 03:58 PM
A tap will clean up any threads AFTERWARDS.
As to getting the bit out a SQUARE extractor would be best, nice and sharp one needed as soft metal, might be best to leave to engineering firm if not confident, as for a few pounds it is not worth buggering it!!
Old May 29, 2007 | 07:20 PM
muffster's Avatar
muffster
Default bleed nipples
Thanks for the replies fellas.
Ive used a tap and die before but what is a square extractor?
Cheers.
Muffster.
Old May 29, 2007 | 08:08 PM
CosKev3's Avatar
CosKev3
Default Re: bleed nipples
Cheers.
Muffster.
Hard to explain,but its a wedged shaped square piece of hard steel that you knock into the snapped nipple,then there is a shaped piece on the top of it that you put spanner/ratchet on and hopefully when you undo it the snapped off nipple will unscrew out of the caliper on the end of the extractor
Some on E-Bay,different design,but should work,just not too sure of the quality for that price
http://cgi.ebay.co.uk/5pc-SCREW-EXTR...QQcmdZViewItem
Old May 29, 2007 | 09:53 PM
daveselwood's Avatar
daveselwood
Default brake
you could try using an easyout
Old May 30, 2007 | 06:27 AM
The best ones I ever used were called WIND OUTS, awsome quality design, stolen years ago when I loaned them to someone.
The main thing to watch is the extractor does not break, I recently used some GLASS HARDENED DRAPER ones like the ebay ones and they were crap, only any use for a bit of thead that is stuck in hole but moves freely!!
ps SNAP ON
Chas
Oct 5, 2015 07:13 PM
muzzman1
Sep 30, 2015 08:59 PM
Myboy22
Sep 16, 2015 07:16 PM
kevin36
Sep 9, 2015 11:12 AM
kevin36
Sep 8, 2015 12:23 PM
