suspension bits
Old May 27, 2007 | 11:58 PM
CozzyBrom's Avatar
CozzyBrom
Default suspension bits
adjustable tcas £160
rear discs brackets £25
rear disc kits less calipers £140
rear link bar kit £500 complete
front adjustable roll bar kit £350
tie bar kit £200
brembo brackets for brembo discs with bolts n spacers £110
Old May 28, 2007 | 10:05 AM
djsri's Avatar
djsri
hi
would the rear discs brackets fit mk4 escort van?
Old May 28, 2007 | 11:06 AM
StephenC's Avatar
StephenC
..BS Motorsport..
whats in the rear link kit? do you do trailing arms on their own?
Old May 28, 2007 | 09:15 PM
CozzyBrom's Avatar
CozzyBrom
Originally Posted by djsri
hi
they would fit on a van if you was going to redrill 2 holes
Old May 28, 2007 | 09:17 PM
CozzyBrom's Avatar
CozzyBrom
the rear link kit is as follows
4 lateral link bars
2 tie bars
10 rose joints
all side spacers and bolts needed
yes i do ajustble tie bars on ther own £200 complete kit
Old May 28, 2007 | 09:59 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
i gather the above is fully adjustable, also does it require coilovers to be fitted ?????
cheers
Old May 28, 2007 | 10:50 PM
CozzyBrom's Avatar
CozzyBrom
yes fully adjustable need coil overs but i could mod your rear arms to a single rose joint
Old May 29, 2007 | 02:55 PM
StephenC's Avatar
StephenC
..BS Motorsport..
dont want to sound thick but the rear tie bars would no longer need bushes right or would they still need them on the hub end?
Old May 29, 2007 | 05:08 PM
CozzyBrom's Avatar
CozzyBrom
if you have 6 link kit no bushes are needed
it you have a single rose joint on the inner end of suspension arm then you need bushes on the hub end same as the tie bar will need bushes
Old May 29, 2007 | 08:12 PM
smitsturbo's Avatar
smitsturbo
pm sent
jessie_rs
62
Aug 6, 2019 09:27 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
S3an
13
Sep 13, 2015 10:01 AM
truffleshuffle
Sep 10, 2015 09:35 PM
