toad ai606 alarm
Old May 27, 2007 | 12:15 PM
daveselwood's Avatar
daveselwood
Default toad ai606 alarm
i was messing about with the key fob yesterday and ive silenced the alarm when it goes off no noise, just indicators flashing,any ideas anyone
Old May 27, 2007 | 01:20 PM
SafeChav's Avatar
SafeChav
Say that again.
You've silenced the alarm, so when it goes off theres no noise
if theres no noise how do you even know its going off?
Old May 27, 2007 | 01:22 PM
daveselwood
Default toad
i know its going off because the indicators are flashing
Old May 27, 2007 | 01:23 PM
SafeChav's Avatar
SafeChav
i see.
Check the connections to the siren in the first instance?
is it a new alarm or old?
Old May 27, 2007 | 01:27 PM
daveselwood
Default toad
ive had it a couple of months i was in programming mode trying to silence it on arm disarm and some how silenced the whole thing
Old May 27, 2007 | 01:28 PM
SafeChav's Avatar
SafeChav
ahhhhhh i see.
You not got the manual for it still then? It shows the menu layout and how to access each feature and change it etc
Old May 27, 2007 | 01:31 PM
daveselwood
Default toad
ive got the installation instructions and part of the manual as iv spilt oil on most of them so im struggling
Old May 27, 2007 | 01:40 PM
SafeChav's Avatar
SafeChav
i think i may have them on my pc in PDF format, not sure though.
Old May 27, 2007 | 01:44 PM
daveselwood
Default toad
if you manage to find them could you pm me please
Old May 27, 2007 | 01:59 PM
SafeChav's Avatar
SafeChav
i have got them mate, and its just a text document
Old May 27, 2007 | 02:23 PM
daveselwood
Default toad
could you post them up please
Old May 27, 2007 | 02:37 PM
SafeChav's Avatar
SafeChav
Be easier to email or send them to you.
Whats your email/msn addy?
Old May 27, 2007 | 02:46 PM
daveselwood
Default toad
email address is davidjhnst@aol.com thanks
Old May 27, 2007 | 02:55 PM
SafeChav's Avatar
SafeChav
sent
Old May 27, 2007 | 03:10 PM
daveselwood
Default toad
cheers mate hopefully that will sort it
Old May 27, 2007 | 03:47 PM
SafeChav's Avatar
SafeChav
Old May 27, 2007 | 04:35 PM
You cannot silence the main alarm function from the key fob as this deletes the point of the alarm(thatcham???), BUT my dad had this some 2 months or so ago on his 4i, and it turned out to be a very small amount of corrosion on the battery terminal between the round post and the clamp and no I could not beleive it either.
It worked perfect, armed,disarmed, triggered etc but no sound, battery ok car starting perfect, need a hefty starter and battery for 4 litre anyway but no sound, thought it worth a go so cleaned up terminal and perfection right away.
ps ai606 as well
Old May 28, 2007 | 01:01 PM
daveselwood
Default toad
still no sound is there a way of testing the siren on its own. i know it has a permanent supply to it and the brown is the trigger wire
Old May 28, 2007 | 06:41 PM
s2 ben's Avatar
s2 ben
i have the same alarm and that is in silent mode to
Old May 28, 2007 | 11:31 PM
SafeChav's Avatar
SafeChav
arm the alarm and unplug disconnect the multi plug to the wiren, it should go off......this may help you determine if the siren is knackered or not.
Old May 29, 2007 | 12:54 AM
zippyobrien's Avatar
zippyobrien
had the same problem on my old mans skyline,
binned the alarm and got a viper one in the end
Old May 29, 2007 | 01:09 AM
SafeChav's Avatar
SafeChav
you can't bin a Toad!
Toads are well reliable
Old May 29, 2007 | 04:31 PM
s2 ben's Avatar
s2 ben
its not the siren as it goes off fine just when i lock the doors it doesnt beep
Old May 29, 2007 | 09:56 PM
daveselwood
Default alarm
armed it and unpluged it while armed and it doesnt go off
Old May 30, 2007 | 12:46 AM
SafeChav's Avatar
SafeChav
back up battery could be shot in the siren then, clutching at straws though
Old May 30, 2007 | 12:46 PM
zippyobrien
viper is a sub brand of toad,
cool alarm to, sends you a text to say if any things wrong lol,
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
Nov 1, 2015 06:53 PM
Rammer46
Sep 18, 2015 08:31 AM
Iain Mac
Sep 13, 2015 09:16 PM
jdsjojo
Aug 26, 2015 10:09 PM
