Would These Fit A 1600CVH?.....
Old May 25, 2007 | 11:46 AM
Lux_Interior's Avatar
Lux_Interior
Default Would These Fit A 1600CVH?.....
Does anyone know weather the cam from a 1400 CVH would fit a 1600 CVH?
Would the tappets from a 1400 CVH fit the 1600 CVH?
Thankyou!
Old May 25, 2007 | 12:11 PM
SafeChav's Avatar
SafeChav
cam will fit but i doubt the profile will be the same.........the lifters are all the same.
I did have a car with a 1400 CVH though a few years back, and it had all over sized components fitted, the lifters were slightly bigger than normal though and from what i can find some engines did come like this from the Factory.
Second hand CVH cams are very hit and miss anyway, the best thing to do would be to buy a brand new cam and a set of lifters...........
Old May 25, 2007 | 12:34 PM
Lux_Interior
Thanks for that
Yeah i'd like to put a new cam kit in but i'm on a proper budget with this one unforch
You say the lifters are probably the same, but oversize?
D'ya think they'll fit?
Old May 25, 2007 | 12:55 PM
SafeChav's Avatar
SafeChav
all CVH's should share the same size lifters, but as i say it is known for some engines to have over size parts, although i dont really have an answer as to why.
To put it bluntly though, budget or not, YOU ARE WASTING YOUR TIME fitting a second hand cam and lifters...........Ł100 MAX for a new cam set
Old May 25, 2007 | 01:07 PM
Lux_Interior
Ok bud, thanks very much for your help
Old May 25, 2007 | 02:26 PM
JesseT's Avatar
JesseT
Let's put it this way. If you are going to use a used cam, then you preferebly should use its lifters and not mix their order up either.
Kyle Langford
27
Aug 5, 2019 07:54 PM
ekjim
Aug 27, 2015 05:20 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
