Relay
Old May 24, 2007 | 05:59 PM
toff's Avatar
toff
Default Relay
Anyone know what the yellow relay behind the dash behind the speedo is for ?
When a turn the ignition on its clicking buts stops once started
Old May 27, 2007 | 08:32 AM
cos231180's Avatar
cos231180
Default 3 door
sorry mate, i cant even put a radiator in myself.
Old May 27, 2007 | 10:12 AM
toff's Avatar
toff
Its cool Tony it cured itself .
you still no got that rad it yet?
disconnected the plugs going to the fans and the one on the bottom right of the rad. undo the bolts that hold the fan in place and remove. take of the top and bottom hoses of the rad. Undo the 2 13mm bolts from underneath that hold the rad in place and its off.
Old May 28, 2007 | 07:05 PM
rscossie86's Avatar
rscossie86
AUSTRIA
when the relay starts clicking again, buy a new one...
When the coil-switches of relays get defect they use to to that - they sometimes recover but I guess it will start clicking again
It could also be a bad mass connection that causes the coil-switch not to switch correctly, though...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
