were can i get a 90degree bend pip like areoquip etc
need one thats going to come out off my rocker for breather pipe so it comes out then faces to the left for a hose to go onto
same as the one in top of this pic but blue?
can someone tell me what size to get also
Don't breath from the back of the cover if you have raised the rev limit above standard - the crank will pick up the oil at high rpm and throw it to the top of the engine where it will then just empty into the catch tank.....
Originally Posted by BROM@ZOO
if you dont rev your engine you will need a -10 -8 bulkhead fitting to screw into the camcover hole then you need a -10 90 fitting in quip your looking around £50 for them to items
how is it held into the camcover? do you need to tap the cover then thread a 90 degree in? i have a catalogue of fittings but all looks complicated
yoy need to tap out camcover to -8 its a male male bulkhead fitting
3/4 unf mate i have loads if you wana borrow one drill cam cover to 17.5mm and tap it i doubt you get a -8 bulkhead/-10 fitting as i had to turn a -10 -10 fitting down you can use a -8 bulkhead if you using 1/2 pipe for your breather but if its 16mm like most then ya need a -10 elbow fitting
hope this helps
hope this helps
well if there is enough meat around the hole may be tap to 20.5 and thread it -10 plus that way it will be cheaper as its a standard fitting needed if not enough meat then tap it out to 20x1.5mm and turn down a -10 fitting again
markk
Aug 23, 2015 09:57 PM
