starting problems
Old May 22, 2007 | 09:44 PM
wide ka's Avatar
wide ka
Default starting problems
tried to start the car for the first time tonight, only for it not to start, ive got a 1600 zetec engine running standard ford ecu and the omex 600 series, there is no spark at all but the coil pack is getting voltage, anyone got any ideas as
im stuck for what it can be, please help!
Old May 22, 2007 | 11:56 PM
FletchCossie's Avatar
FletchCossie
Crank Position Sensor iirc...
Had similier problem on my Vaux Astra. Tried 2 new sensors with same problem. Fitted an 97,000 mile one and it still works now
Edited to say: My Astra was receiving all voltages iirc, but it was not receiving the correct signal from the sensor, hence it didn't know when to spark!
Old May 23, 2007 | 12:00 AM
melzieann's Avatar
melzieann
if there is a voltage at the coil but nothing coming out i would say it was the coil itself, i have changed a few coils on Zetecs for simular problems
Old May 23, 2007 | 12:08 AM
zippyobrien's Avatar
zippyobrien
like i said, if your ecu is saying its ofline, then i think its a programing fault
Old May 23, 2007 | 10:39 AM
pani_k's Avatar
pani_k
PassionFORD Member
input voltage at the coil pack, no output voltage suggests coil pack itself as melzieann said
Old May 23, 2007 | 11:06 AM
wirralphil's Avatar
wirralphil
was gonna say that meself.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
