wire rung blocks and cometic gaskets
Old May 22, 2007 | 08:39 PM
Alps Pacino's Avatar
Alps Pacino
Default wire rung blocks and cometic gaskets
Ye or na basically, my rs500 block was wire rung but used a grpA gasket, now i have always used cometic and had no problems at all apart from there rocker cover gaskets lol so thougt i would use a cometic on my fresh build which will be using a normal 205 block as the rs500 block is cracked so do i get the new block done or not as i have heard that cometic gaskets dont like wire rung blocks???????????????????
Old May 22, 2007 | 08:42 PM
Billabong's Avatar
Billabong
Nope - std type head gasket with wire rung block only. (i.e. either std or group A, but not multilayer steel)
The Youth.'s Avatar
The Youth.
wiring ringing is old school stuff mark, just stick a grp A gasket in job done, or skim the block and head and fit a cometic
steve
Old May 22, 2007 | 08:46 PM
Dicko&Vacant's Avatar
Dicko&Vacant
see mark i do know some things pmsl
Old May 22, 2007 | 08:48 PM
Alps Pacino
cometic is bought now its going to amac engineering who are the bollox aparently so i'll see what he says. I'll get the head checked and hopefully it wont need a skim as it didnt overheat and the head gasket didnt go it was all down to the blocks fault, if it needs a skim it will be lightest skim humanly posible as there aint much meat left on the head tbh.
I was just wondering if it was worth doing while i'm on with it cause its going to get 100% pure death all summer
Old May 22, 2007 | 08:49 PM
Alps Pacino
Dicko&Sarah
Ye but see how much confidence i have in you
Old May 22, 2007 | 08:58 PM
Billabong's Avatar
Billabong
Well here's a free tip: If he says yes to wire ringing it and the Cometic, find another engineering place that's the bollox
Old May 22, 2007 | 09:04 PM
col cos1's Avatar
col cos1
group a with wirerung
Old May 22, 2007 | 09:07 PM
RS500/364's Avatar
RS500/364
Default Re: wire rung blocks and cometic gaskets
I will give you £50 for the block and shells caps
Old May 22, 2007 | 09:25 PM
Alps Pacino
RS500/364
I bet you will lol, its repairable not completely fucked, just i wouldnt like to risk it with decent bhp, paul nyrss has offered me £50 so you can go head to head on gaybay if you want lol. Ps if it has arp main studs it will be coming with them to as i bought new for piece of mind
Old May 23, 2007 | 05:43 AM
RS500/364's Avatar
RS500/364
PM me the link when you do ebay
Old May 23, 2007 | 05:45 AM
RS500/364's Avatar
RS500/364
Mind you i even have a spare block pistons freash and ready to go deal even ?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
20/20 vision
Sep 29, 2015 11:27 AM
