turbo fitment
Old May 21, 2007 | 07:25 PM
havv's Avatar
havv
Default turbo fitment
alright all,
i need a new turbo on my s2, smokes comeing out militantly out the exhaust, bit not out the turbo, and the turbo gaskets have gone, not sure what else.
anyone know the fitments and dimentions of the s2 '89 turbo? can i fit any t3 on or are they specific to each vehicle? any onther cars with the same turbos?
also is it worth getting this reconditiond or just to get a new one??
cheers.
Old May 21, 2007 | 07:45 PM
SafeChav's Avatar
SafeChav
make your life easy and just get a new turbo, or an exchange one.
Your turbo can't definately be slavaged, most places offer an exchange rather than a re-furbished service.
Old May 21, 2007 | 11:50 PM
Carlsworth's Avatar
Carlsworth
Former Sponsor
hi there
sounds like there a crack inside the core
it can be replaced, and will be much cheaper than buying a new turbo
if you want prices etc, give me a bell on 01253 296160 or 07960 935815
carl
Old May 22, 2007 | 05:18 AM
Might as well pay a bit more and get 360 and step gap at same time ?
Old May 22, 2007 | 09:32 AM
Carlsworth's Avatar
Carlsworth
Former Sponsor
Thats true tabetha,
For the little extra charge, its wise to have the 360 and stepped rear seal seen as the unit is in bits anyhow.
Saves paying for it again if in the future you want the scope to run more boost.
Carl
Old May 22, 2007 | 10:15 PM
havv's Avatar
havv
how can the core crack? what and what would be the aymptoms. would i no longer have any boost? would the turbo spin??
Old May 22, 2007 | 11:13 PM
SafeChav's Avatar
SafeChav
If its cracked you'll get similar symptoms to when the headgasket fails, oil & coolant mixing.
It would still work but not for long before it ceases up i should imagine.
Old May 23, 2007 | 12:12 AM
Carlsworth's Avatar
Carlsworth
Former Sponsor
pretty much as safechav said, the journal bearings get so hot they weld themselves to the shaft....
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
