anyone know anything about SATA hard drives ????
please help, just been to aria and got a new hard drive and a serial controler card
plugged it all in but the hard disk isnt showing in my computer ?
i was sure that you didnt need two drives is this correct ?
any ideas what im doin wrong ?
cheers......matt
cheers......matt
is there a boot disk with the controller card? if so when booting from xp setup disk, press f6 key( i think it is) to boot up the controller card. it will ask for the drivers for the controller card so put the disk in. then it should see the drive and continue to install windows.
Originally Posted by slowpoke
anyone else got any ideas or anything ?
the drive is there in device manager but it still isnt showing in my computer
doin my head in now
doin my head in now
If not that's why it's not working.
If its a seperate controller card then the motherboard won't need drivers, the PCI controller card will.
You will probarly need to run 'diskmgmt' in the system32 folder of your windows install.
That will enable you to format the drive etc and make it visible to your windows install.
Hope some of this helps.
TPM961
Jan 15, 2018 10:50 AM
