ignition problem - tempremental
Old May 19, 2007 | 10:23 PM
havv's Avatar
havv
Default ignition problem - tempremental
hi all, have a problem with the ignition. sometimes the car starts fine, but a lot of the time when i turn the key, nothing happens at all except fot the battery turns on, the elctrics turn on, and i can hear the fuel pump engaging. but if i turn the key, nothing even tickes over. then as i keep trying itl randomly work with help of the throttle.
any ideas??
Old May 19, 2007 | 10:39 PM
Series 1 van's Avatar
Series 1 van
duz engine not turn ova either
Old May 20, 2007 | 06:46 AM
If it's a focus, a new ignition sswithc as they burn the contacts inside the sswitch itself, other wise you need to determine if it is the switch or the starter, test light time!!
Old May 20, 2007 | 02:38 PM
havv's Avatar
havv
no theengine doesnt turn over. sorry its a s2 escort
Old May 20, 2007 | 02:46 PM
Series 1 van
take bottom ignition plastics off try start it with screwdriver if it starts its the black ignition cap had this happen loads
Old May 20, 2007 | 04:01 PM
havv's Avatar
havv
how do you mean with a screwdriver?? no i da how to do that...
Old May 20, 2007 | 05:41 PM
havv's Avatar
havv
done! thanks works sall the time with screwdriver!
Old May 21, 2007 | 05:13 PM
Series 1 van
its ur ignition cap thats worn happens all the time with mk4s
Old Jun 11, 2007 | 07:21 PM
FAST FORD's Avatar
FAST FORD
can you explain please what you did in greater detail here as i think im having a simlair probelm with my Mk4 XR3i ( MFi ) Cheers !
Daniel Howard
17
Sep 26, 2015 12:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
marky_g
Sep 12, 2015 04:26 PM
