COULD BE A SILLY QUESTION BUT.....
Old May 18, 2007 | 10:02 AM
Gti Killer's Avatar
Gti Killer
Default COULD BE A SILLY QUESTION BUT.....
When the fan turns on is it supposed to suck in cold air or suck out the hot air
Old May 18, 2007 | 10:32 AM
JohnP001's Avatar
JohnP001
The idea is to suck the cold air through the radiator, thereby cooling the water within the radiator. It tries to simulate driving conditions, when air is naturally forced through the radiator, thereby cooling the water. (I’m assuming that you’re talking about the radiator fans?)
Old May 18, 2007 | 10:44 AM
Gti Killer's Avatar
Gti Killer
YEAH I AM MATE IT SEEMS TO BE BLOWING OUT
Old May 18, 2007 | 11:10 AM
JohnP001's Avatar
JohnP001
Are you sure? When the fans come on, put a small plastic bag on the radiator front, but don’t cover the whole radiator, and if the bag gets sucked on, then it’s working OK, and if blown out then not. I can’t see how the fans can be reversed, as the electrical plugs should only fit on one way. What car are you experiencing this problem on?
John
Old May 18, 2007 | 11:26 AM
Gti Killer's Avatar
Gti Killer
89 S2 RS TURBO ILL GIVE THE BAG TRICK AGO MATE
Old May 18, 2007 | 11:27 AM
Gti Killer's Avatar
Gti Killer
SORRY THANKS TOO MATE
Old May 18, 2007 | 02:14 PM
SafeChav's Avatar
SafeChav
it may well appear its blowing the wrong way its on as air deflects off the radiator.
Pretty sure its supposed to spin clockwise as you look at it
Old May 18, 2007 | 05:41 PM
cos jon's Avatar
cos jon
Have you got it wired in the correct way round ??
Rod-Tarry
75
Oct 13, 2015 04:44 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
