gearbox oil
Old May 17, 2007 | 08:33 PM
muffster's Avatar
muffster
Default gearbox oil
Hi guys
Can anyone give me any tips on changing the gearbox and diff oil on a 2WD saph cos please. The old stuff has been i there years, can it be drained out and how do i know when ive put enough in?
Thanks.
Muffster.
Old May 19, 2007 | 01:21 PM
2001ode's Avatar
2001ode
Hi,
For T5 gear box, you have drain plug to change oil.
2.5 liters Dexron automatic gear box (finis 50 14 519 one liter)
For rear axle, no plug drain exist. If you want change oil anyway, it's necessary undo all screws to separate rear plate housing.
1 liter EP 90
Regards.
Claude
Old May 19, 2007 | 05:03 PM
costina's Avatar
costina
Live long and prosper!!
Use a piece of tube (hose pipe) fit a sutable metal end so it fits into box and run pipe up to rear of turbo fit a small funnel to pipe and fill....
once fluid starts to come out of filler hole JOB DONE
Old May 19, 2007 | 06:49 PM
muffster's Avatar
muffster
Default gearbox oil
Nice one cheers guys.
Muffster.
Old May 20, 2007 | 06:51 AM
I used ATF(g/box), and used also GREASED LIGHTENING, improved it no end on changes!!
Old May 20, 2007 | 01:49 PM
muffster's Avatar
muffster
Default gearbox oil
Never heard of greased lightening before, what is it and where can i get it from?
Cheers.
Muffster.
Old May 20, 2007 | 02:13 PM
It is a thick goopy liquid type stuff, in a black bottle and i got mine from WILCO but am sure halfrauds do it as well.
Despite what ford say the T5 was never designed for ATF, as this eats the pads on the selector fork ends which are made of a compressed card!!.
The greased lightening made a huge difference, to change feel and smoothness, but my box is a bit ropey anyway!!
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flateric_2002
Sep 15, 2015 08:41 AM
Adam Graham
Sep 6, 2015 06:04 AM
