wire rung block
Old May 15, 2007 | 07:45 PM
mk4gartrac's Avatar
mk4gartrac
Default wire rung block
Hi my block is wire rung is this a good thing? im about to replace the head whats the best way of cleaning the block face and do the rings need replacing? ive found one is loose is this ok?Any help would be great im all fired up and want to get her running for the sumer
Old May 15, 2007 | 07:58 PM
Alvyn's Avatar
Alvyn
the wire rings WILL need replacing m8!
Old May 15, 2007 | 07:59 PM
mk4gartrac's Avatar
mk4gartrac
Easy job????
Old May 16, 2007 | 08:37 PM
mechanic28's Avatar
mechanic28
oh ouch wot car ???i have got a coopers O ring headgasket on my 2wd sapp cossie
Old May 17, 2007 | 05:26 AM
mk4gartrac's Avatar
mk4gartrac
4wd cosworth.I spoke to an engine builder yesterday and they said i can ither throw them away and use an uprated head gasket or i can hold them in place with a lil bit of blue gasket sealer and they will be fine but he did say he never recomends using wire rings.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
