oil leaking from end of cam....HELP
Old May 15, 2007 | 07:15 PM
M K's Avatar
M K
Default oil leaking from end of cam....HELP
bit of a strange 1,
i recently snapped my cam in half long story available in my resto thread
ive fitted a new head that was from my mate tom scarletts 300bhp s1, now the head was all built up when i put it on, head,valves,lifters,rockers etc along with a vernier pulley,
the pully was not bolted to the cam tho,
now ive fitted it all up and the car runs fine but im getting an oil leak from the end of the cam itself where the vernier bolts on it is not coming form the rubber seal around the cam as there is no oil whatsoever there, its driving me mad as its making a right mess flicking oil all over the show,
here is pics of the vernier,sensor set up all bolted on then a pic with the sensor pick up and bolt removed to show the oil seeping out
is there meant to be an o ring or something there or is the reason its leaking oil because i have not thread locked/sealed it as i wasn't sure if the sensor was in the right place? if was to seal it with thread sealer would this stop it ok
thanks
Old May 15, 2007 | 07:57 PM
M K's Avatar
M K
been told there is usally a bearing in standard cams that stops this but a bit of thread sealer/lock will stop it fine so happys days & all is good
Old May 15, 2007 | 08:01 PM
SafeChav's Avatar
SafeChav
let me guess? Piper cam by any chance
Old May 15, 2007 | 08:25 PM
M K's Avatar
M K
not sure what blank was used mate but no its not a piper, although it was profiled with some of the piper 285t2's characteristics
Old May 15, 2007 | 09:17 PM
SafeChav's Avatar
SafeChav
Piper are classic for this......i suppose its all about saving as many pennies as possible though
Old May 17, 2007 | 05:32 PM
M K's Avatar
M K
unfortunately thats true mate,
quantity not quality for some firms
Old May 17, 2007 | 05:35 PM
SafeChav's Avatar
SafeChav
sadly so
Old May 19, 2007 | 12:04 PM
GraphiteGray's Avatar
GraphiteGray
I had the same problem when i fitted a new cam to me RSi a while back, couldnt understand why it was doing it but then i was told to coat the pulley bolt thread with loctite before refitting it, no problems since
Something to do with the cam sweating the oil out i was told?
Old May 19, 2007 | 12:34 PM
SafeChav's Avatar
SafeChav
what absolute BOLLUCKS lol
The cam has holes drilled through it to help oil flow where the cam runs against the head surfaces, so oil enters inside the same, the better cams inclusive of Ford ones, have ball bearings pressed in to stop the oil running out the end.
Cheap/poor quality ones don't
Old May 19, 2007 | 12:39 PM
GraphiteGray
A non-believer eh?
Mine was a kent cam and it wasnt hollow at the pulley end? couldnt see any ballbearings either?
Old May 19, 2007 | 03:46 PM
mudder's Avatar
mudder
Yep i think its a piper cam my mate hase one with the same prob.
Old May 20, 2007 | 08:59 PM
Canada1's Avatar
Canada1
Default cam position sensor assembly
Where did you get the cam position sensor (trigger assembly and pickup assembly)?
I am putting together a Haltech E6S management system, and would like to use a cam position sensor for full sequantial operation.
Perry
Old May 20, 2007 | 10:01 PM
M K's Avatar
M K
sensor set up is a FIELD MOTORSPORT design
give them a call on 01245 320 730 and ask for tommy, tell them your after the same set up from the blue mk2 xr2 turbo that they built the engine for
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
BRAMMER
15
Sep 14, 2015 08:52 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
rsstav
Sep 7, 2015 04:43 AM
hopper350
Sep 4, 2015 12:53 AM
