Coil Springs
Old May 15, 2007 | 06:26 PM
monkey24's Avatar
monkey24
Default Coil Springs
Can anyone give me a step by step guide to changing mondeo front coil springs?
1999 2.0lx
Do you need to take the allen key screw out of the strut mounting nut completley.....any one got any tips?....im doing my best with a haynes manual.
Old May 15, 2007 | 06:39 PM
James998's Avatar
James998
By the alan key screw, do you mean the one inside the threaded bar, down the center of the strut?
If so, no. Hold that with a ratchet and crack off the nut on the threaded part, wind that down the thread and remove the cup at the top of the spring and anything else with it.
By the way, if you don't have a spring compressor at this point, youre fucked.
Old May 15, 2007 | 10:23 PM
SafeChav's Avatar
SafeChav
Its always fun undoing that nut and watching the spring fly off
never tried refitting it without a spring compressor though
Old May 15, 2007 | 11:46 PM
monkey24's Avatar
monkey24
i have spring compressors.......anyone got an opinion on this?:
https://passionford.com/forum/viewto...880785#3880785
Old May 16, 2007 | 07:32 PM
James998's Avatar
James998
I was kind of hoping he read the entire post before following it
Old May 16, 2007 | 10:01 PM
monkey24's Avatar
monkey24
dont seem to be able to compress the new spring enough to get it all back together.
anyone help?
Old May 16, 2007 | 11:56 PM
SafeChav's Avatar
SafeChav
You sure they are right springs then?
Old May 17, 2007 | 07:26 PM
James998's Avatar
James998
How many coils do you have the spring compressor on?
Put it on as many as possible.
Old May 17, 2007 | 07:43 PM
monkey24's Avatar
monkey24
they only reach over 3 springs.....id have been ok if i had a couple of pairs of compressors....could have clamped them down as far as possible and then used second set to take them down....anyway.....found a gargage that put the new springs on with a hydrolic compressor £30 for the pair so im happy....still saved a fortune. only 1 side left to do then its ready for its re-mot on saturday.
cheers for you replies.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
beller
Sep 21, 2015 04:13 AM
