zetec turbo internals question
If you done a zetec turbo without changing any internal (pistons / rods / bolts etc...) and used a decomp plate to lower the compression (i know I know! lol), how much boost / power could the standard zetec internals take ?
Thanks.
Thanks.
Thanks.
Thanks.
300bhp
Standard pistons wont take 25psi will they ?
sorry my bad no i had a set of calibra pistons 1 bar max on standard pistons
makes a bit more sense
, everything else internally was standard ?.
What compression ratio do the calibra pistons run ?
7:8:1
