Rev counter
Old May 14, 2007 | 08:01 PM
george the greek's Avatar
george the greek
Default Rev counter
Hi there
I have a mk6 escort with a fiesta turbo engine everything works fine except the rev counter that shows what ever it feels like usually I think half the revs of the engine. I tryed to run a wire straight from the coil the rev counter but it didnt do anything. Any ideas what could be wrong???
thank you in advance
Old May 14, 2007 | 10:20 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its in wasted spark configuration and will always read a max of half what your engine runs at. You need to get an EFI tacho.
Old May 14, 2007 | 11:04 PM
SafeChav's Avatar
SafeChav
The only thing i would say Stu........surely on Mk6's theres hardly any cars that run a conventional coil?
I've not seen any myself, even the pissy 1.3 HCS tap monsters run coil packs
You could try connecting the rev counter input to Pin 11 of EDIS, may solve your problem
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
cozzy jeff
Aug 14, 2015 05:46 PM
