oh shit
today on the way to cumbria rsoc i blew a hole in my block
am gutted to say the least looks like a con rod has came through the block and ive now got a hole the size of my hand and found my big end shell on the m6
i was cruising in a convoy and heard a pop then smoke so i killed the engine and pulled over but i dont know what to do now
Lewis has you car not got steel rods in it with forged pistons.
Were you cruising or slowing down from a high speed blast
Sorry to hear about it, its never good to open the bonnet and find out bits of your car have dissapered or fallen off
Originally Posted by Coldo
Not good mate
Anyone else reading this and bricking it about taking their rs out?
Car is better for it now, everything works all the time and I have no fear putting the foot down or going on a long run anymore
Just need to try and avoid foxes crossing the road in future
You'll be back mate, mibbe a few ŁŁ's lighter but what the hell eh?
SMG
cheers for the kind words
got the car towed back to scotland lastnite just put it in the garage ive not even went back to look at it
so pissed off i still dont know what happend as i was just cruising and it went without a rattle or knock
the bottom end as davie said was highly spec'd and prob wont know til iget it stripped what caused it
just got a new house so couldnt have happend at worse time
wont be on the road any time soon unless i can get a low comp block cheap
Really sorry to hear this Lewis, browsing about the west website have you not long put it back on the road?
Just leave it for a few days cool yerself down then go have a look, once you get it apart and get the bits youll be champing at the bit, just cash though mate.
Best of luck to you mate, plenty folk about to give you a hand
Pete
(mines been of the road since october
Pete
Lewis's bottom end
Low compression bottom end. Farndon steel crank, arrow steel rods, accrelite pistons 0.5mm oversize, A.R.P rod bolts, A.R.P flywheel bolts,
Looks very strong but it let go so easily
Deffo dave, doubt a seized piston would do that.
I would have thought that ARP's would be statutory on any rebuild not just a power build, hopefully lewis might still have the build receipt from the last owner which can back this up and hopefully not a bodge.
still its not impossibly that they could fail
davie i still have all recipts all work was done at power enginering i must admit mate am totaly stumped
could it be ware and tear as pete said
i do know the prev owner thrashed it big time
just hope i can salvage the goodies in there
in the pics mate you cant see that there is a hole in the sump too
all i could find was a big end shell and bit off my block on the road
Could the conrod bolts have worked loose and sheared off? Sorry to hear about your misfortune
As said above you just dont expect that sort of thing to happen with a spec like that
As said above you just dont expect that sort of thing to happen with a spec like that Thread
TPM961
Jan 15, 2018 10:50 AM
Mc5506
Oct 5, 2015 09:57 PM
Ben26
Aug 27, 2015 08:56 PM
