3 door top speed question
Old May 12, 2007 | 11:38 PM
Tank Mike's Avatar
Tank Mike
Default 3 door top speed question
i you were to have a 550bhp engine, with standard ratios in the box and diff, what is the car geared to do top end?????
Old May 12, 2007 | 11:43 PM
R4N SS's Avatar
R4N SS
i thought it was nearer 170
Old May 12, 2007 | 11:45 PM
Rick's Avatar
Rick
it will hit the rev limiter in 5th easily!
A 330hp RST wil nigh on crack 170...
Old May 12, 2007 | 11:48 PM
SapphyMike's Avatar
SapphyMike
depends on the revs / wheel size..
Old May 12, 2007 | 11:49 PM
Kevin Sharp's Avatar
Kevin Sharp
235mph
Old May 12, 2007 | 11:53 PM
SapphyMike's Avatar
SapphyMike
Originally Posted by Kevin Sharp
235mph
is that all?
my 204bhp cossie managed 350mph running on 3 cylinders.
Old May 13, 2007 | 12:18 AM
Rick's Avatar
Rick
rick talking shit as usual
What?!
Seeing as Christian has done 168.8 within the confines of brunters 2 miles i cant see ur point
Old May 13, 2007 | 01:12 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
235mph
With an appropriate rev limit set, that is indeed the correct answer as to what it would be geared for.
Old May 13, 2007 | 05:14 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Depends on the Rev limit.
Steve.
Old May 13, 2007 | 07:53 AM
Rod Tarry's Avatar
Rod Tarry
Tell me the tyres/Wheel size + Rev Limit & I will tell you exactly what it should do.
A correctly geared 550bhp 3 dr Cossie will hit about 183mph within the confines of Brunters. Bruce Reed did 182.6mph there in a 3dr with a Dynoed 541bhp.
Rod
Old May 13, 2007 | 08:08 AM
Tank Mike's Avatar
Tank Mike
Rod
205/45/17 i think, defo 17 though, i susopse the engine will rev limit near 7500. as its still on hydrolic lifters, (need to dicch them if anyone knows where i can get solids)
thanks rod
Old May 13, 2007 | 08:11 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Rod
205/40/17s, standard diff + 7200rpm Rev Limit
Thanks
Steve.
Old May 13, 2007 | 08:52 AM
Ryan's Avatar
Ryan
i would like to see 156.9 if i ever did it in mine.
Old May 13, 2007 | 03:16 PM
rapidcossie's Avatar
rapidcossie
8k limiter on 235/40 17's is 195mph.
would need a bout 650 to hit that at brunters tho.
Old May 13, 2007 | 03:21 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Rod
Thanks
Steve.
170mph
Old May 13, 2007 | 03:26 PM
TIFF's Avatar
TIFF
Chasing Radders
I did 168mph going on the GPS....that was with 18's.
Old May 13, 2007 | 03:30 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Rod
Thanks
Steve.
170mph
Thanks Mike
Steve.
Old May 13, 2007 | 03:33 PM
Nash's Avatar
Nash
Cake lover!
205/40/17 tyres on a 550bhp 3dr?
What about a 420bhp 2wd Saph with standard box and diff, 7200rpm limiter, and 235/40/17's. Just out of personal interest.
Old May 13, 2007 | 03:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
More than 170mph
Steve.
Old May 13, 2007 | 04:34 PM
Kevin Sharp
Rod
you sure rod?...my 3door did 183mph and was only around the 500 mark
Old May 13, 2007 | 04:51 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Rod
Sorry Kev .
Kev is totally correct I had forgotten his record run. 183mph with standard brakes if I remember correctly , so perhaps 185 is possible in a 3dr with 550bhp. MADAde did 185.5 with 550bhp in a Saff.
Rod
Old May 13, 2007 | 05:00 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
thanks rod
Tyres 205/45/17, if you could pull 7500rpm (maybe past peak Power) that would be 181mph.
Tyres 205/40/17, with 7200rpm limit is 168mph.
Old May 13, 2007 | 05:18 PM
rapidcossie
Rod
thanks rod
the engine will rev to 8 with no trouble on normal lifters etc
Old May 13, 2007 | 05:22 PM
Mike Rainbird
Caraholic
Rod
thanks rod
True, but holding them at that speed and they go WAY beyond their efficiency range and sound like a bag of spanners afterwards, as all the oil gets pumped out of them if held too long at these kind of revs. Obviously they recover again, but it is not an ideal situation for a high revving engine, as you only have to visualise what is happening to the springs with the lifters locking...
Old May 13, 2007 | 05:24 PM
Tank Mike's Avatar
Tank Mike
where can i et solids????
Old May 13, 2007 | 05:25 PM
rapidcossie
Rod
thanks rod
I have never had any trouble on my engine Mike....it has always sounded sweet after any held runs on the rollers or top speed runs.
Maybe I am just lucky
Old May 13, 2007 | 05:28 PM
Tank Mike's Avatar
Tank Mike
yer but my lifters are wanked anyway, they sould like a bag of nails from start up lol. if im gunnna strip it all down and repalce them i might just a well go solid then its done and i can push it hard if i feel the need
what boost are you running at 8k
Old May 13, 2007 | 05:29 PM
rapidcossie
2.2bar at the limiter
Old May 13, 2007 | 05:30 PM
Tank Mike's Avatar
Tank Mike
shite thats alot, crank and rods can't be standard are they??
Old May 13, 2007 | 05:32 PM
rapidcossie
yeah
Old May 13, 2007 | 05:33 PM
Mike Rainbird
Caraholic
It's not just a matter of the lifters, you then need to change the cams to suit this type as well.
The benefit of running solids is that you can run MUCH more aggressive cams, due to removing the compromise you have to have on the lobe shape when you run hydraulic ones.
With the cam timing swung, I could move my peak power up by 500rpm to take it from 7500, to 8000, purely because the cams and solid lifters can do this .
Tank Mike's Avatar
Tank Mike
fair play mate
Old May 13, 2007 | 05:35 PM
Tank Mike's Avatar
Tank Mike
i've got db16 inlet and exsaust, double springs and v pulleys. do you think its worth it with that set up
Old May 13, 2007 | 05:43 PM
Mike Rainbird
Caraholic
It depends ENTIRELY on where you want the power band to start and end.
