2.0 engine swap problems
Old May 10, 2007 | 08:13 PM
need.more.power's Avatar
need.more.power
Default 2.0 engine swap problems
I've just fitted a 2.0 black top out of a t reg mondeo into a l reg fiesta xr2i which was a rite carry on as they are different water pump set ups and I'm having problems with the ecu . i can get it 2 run on the xr2i ecu but not the 2.0 one it wont start . the only thing i can think of is the 2.0 is chip key but i don't av the keys plus my xr2i doesn't av the wiring around the column for the chip key. does any one know a way round this or a way to wire the chip up as i cant run on the xr2i ecu as it under fuels and will cause damage. any help on this will be gratefully received.
Old May 10, 2007 | 08:53 PM
sailorbob's Avatar
sailorbob
Which 2.0l ecu are you using?
Old May 11, 2007 | 12:02 AM
SafeChav's Avatar
SafeChav
The 2.0 ECU will never be plug and play, you'll probably find the 2.0 one has internal PATS & EDIS, and i expect your old ECU doesn't.........
Old May 11, 2007 | 01:20 PM
need.more.power
Default ecu
if only it was that easy to just plug and play. the ecu i have is taxi and the one originally on the car was a 2fcd.
Old May 13, 2007 | 07:49 AM
sailorbob's Avatar
sailorbob
The 2FCD ecu has external EDIS and the TAXI ecu has internal EDIS so they aren't interchangeable.
There is a post as to how to convert your loom to use an internal EDIS ecu here http://www.fiestaturbo.com/forums/2-...t-vt130795-35/ by 'Jack The Lad' that I think will work as I believe the pinouts of the 2FCD are the same as the RS1800 this guide was written for.
I don't know if your TAXI ecu will give a PATS problem, if it does you will need to find a DEWY, DEEP or DESK ecu.
JoeyBoyden
Jan 4, 2024 02:36 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
