Sapph problems
Old May 9, 2007 | 05:54 PM
Delvmatic's Avatar
Delvmatic
Default Sapph problems
Car was running fine the other day but then yesterday it was practically undrivable because of severe backfiring. Fuel level was just under quarter tank so topped up to make sure this was not a problem and still the same. I could hear a buzzing sound at one point just by the fuel line when key was turned in the ignition (although engine not running). Not sure if it was a sensor. The car had no power and really struggled.
When i tried to start the car today it wouldn't even start! Turned the key and could just hear the starter whirring. Would not engage, which has stumped me. I got car towed home and now have no clue where to start. Have noticed my fuel pump is a little noisey and there is a wee bit of a whiff of petrol from it so that maybe could be a part of the problem.
Any help would be most appreciated
Thanks in advance,
Delv
Old May 9, 2007 | 06:39 PM
Firstly is the pump priming inposition 2 ?
If not your CPS sensor, or more likely it's connector is playing up, try to wiggle test it as well.
If your pump sounds more noisy than normal it could be this is on the way out/gone out!!
When was your fuel filter last changed ?
You could always check for fuel delivery by disconnectiong fuel rail and MOST IMPORTANTLY THE COIL and just run on BRIEFLY to see if petrol gushes into a container.
Cps connector is a fav dodgy one, just cut it out and put new one in.
Old May 9, 2007 | 07:51 PM
Alvyn's Avatar
Alvyn
also check the coolant temp sensor which is located at the passenger side rear of the cylinder head!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
