mk6 escort gti /2 ltr lump ?
hi my dad has a mk2 mondeo just had back end damage said i can have the car
ass i have said iv got the 1.8 16v engine in mine will the 2 ltr out of my dads car go straight in my car and use my loom
and just plug my dads 2ltr ecu in will this work
just after more info thanx ste
is it a silvertop or blacktop engine, because i believe the blacktops had the pats module in the ecu, so unless you have the original locks on, the car won't start. pretty sure thats right, someone correct me if i'm spouting madness
True.
You will need a DEEP ECU, might be worth checking.
It will go straight in if it is a Silvertop engine (literally, silver cam cover).
Worth the upgrade, although it will need your 1.8 waterpump and sump fitted
Weekends worth of work if you have all the right stuff and an able mate.
hi its a silver top engine
i didant think i will have to change the sump over and water pump
so say i did all that
and i put the engine in will my wireing loom plug into the 2 ltr and
connect the 2ltr ecu into my 1.8 ecu if you understand me lol
you can use all the electrics from the car, a chip may help but the MAF sensor should cope ok.
to get the engine in tho you need to change:
Water pump (might as well do cam belt and tensioners while your at it)
Im pretty sure the mondy oil pump is ok, but the oil filter pokes a bit further out
you need to change over the oil pickup pipe and the sump
you need to change the flywheels and clutch over unless your GTI has an MTX75 gearbox (will have a lift reverse if so, if its normal ford bottom right reverse its an IB5 box)
and thats it
and thats it
Theres a wiring guide on escortevolution.co.uk that allows you to run the 2.0 ECU. You'll need the 2.0 TB, MAF and Injectors tho, oh and was the mondeo manual? as the automatic ECU's wont work. also use the escort flywhel and gearbox.
link:
http://www.escortevolution.co.uk/for...howtopic=49026
link:
injectors and sensors are the same as the 1.8 ones
MAF sensor 'may' be be bigger, but pretty sure its the same
forgot about the thrtolle body, the mondy one is 52mm and the escort one is 48mm, so use the mondy one too
1.8s are brown too, so the same as 2.0l
mine was a converted 1.6 > 2.0l as well, all the cam sensors, crank sensors etc are the same, but quite rightly the MAF and TB is diff
think the 1.8 MAF is the same as a 2.0l however, but i could be wrong
tb size i quoted earlier was for 1.8/2.0l
not sure on 1.6 size, think it could be 45mm?
well iv got a 1.8 gti engine and it aready has the 2ltr cams throtell body and maf cencer on and its and it has bean super shipt
then gear box is manuel but i was going to use my 1.8 gear box ass be a lot quicker threw revs ?
will this work ?
will this work ?
