ZETEC timing belt
Need pointers . I am in the process sorting my fiesta and i got to the cambelt
, i know how to time up the cams but no timing marks on the crank pully
any ideas of making sure it all bang on with out the head off
Originally Posted by The Diva
To time a Zetec up safely you will need the timing pin kit......
which zetec engine is it? if there are no marks it sounds like an se version which don't have wodruff keys to locate the pullys. if so you definately need a timping pin set to lock the engine otherwise things will bend
ive never used a pin,
on the escort and mondeo sump there is a flat plain, about the 4o'clock
position as said, line this up witht he 2nd notch on the crank pulley, or remove plug no.1 and use a socket extension you can see when the piston is at tdc. or use a dial indicator...
slacken the cam pulleys and use a 5mm thick bar to slot in the back of the cams and then fit the belt.
fit the belt and tension it as per the haynes manual etc (or if you buy a gen ford belt it comes with instructions) tighten everything up etc
and crank it over by hand and chack that the pulley lines up and the plate sltos int he cams.. if not, adjust till it does lol
No pin then if its silver top
Just line up the timing mark on the bottom pully with the triangle bit to the right of the bottom pully then off with the rocker cover insert the 5mm thick bar into the slots on the back of the cams remove belt and replace it (you really should do the full kit which will involve the pully replacements too dont just do the belt you will regret it)
borboyous
Aug 22, 2015 11:17 AM
