Oil for e36 3.2 evo??
Old May 8, 2007 | 06:53 PM
Butch.'s Avatar
Butch.
Default Oil for e36 3.2 evo??
i know this is a ford forum but i just got my new bmw and wondered what oil people used in them? and what plugs are best for them??
cheers
Old May 8, 2007 | 06:55 PM
Ginge !'s Avatar
Ginge !
just finding my feet
crisp and dry
Old May 8, 2007 | 06:59 PM
Butch.'s Avatar
Butch.
cheers for your help ginge
Old May 9, 2007 | 06:32 AM
jaiscossie's Avatar
jaiscossie
Get your ass over here mate,loads of info on them
http://www.e36coupe.com
Old May 9, 2007 | 06:34 AM
Butch.'s Avatar
Butch.
have joined them now some good tips on there
Old May 9, 2007 | 06:50 AM
jaiscossie's Avatar
jaiscossie
Here you go
http://www.e36coupe.com/forum/viewto...er=asc&start=0
Old May 9, 2007 | 08:02 AM
JjCoDeX75's Avatar
JjCoDeX75
No matter what anyone else tells you, the only approved oil for that car (IIRC) is Castrol TWS. It costs a fucking fortune.
I have the same issue with my M5.
Best I can offer you is to find the castrol classic oil page, and buy direct. BMW will try to sell you a litre for about 14-15quid!!!!! You can get direct a little cheaper (works out to be 10quid a litre)
Cheers mate
JJ
Old May 9, 2007 | 09:01 AM
AlexF's Avatar
AlexF
http://www.castrol.com/
theres a "which oil should I use" link at the bottom on the left!!
Alex
Old May 9, 2007 | 09:58 AM
Jim Galbally's Avatar
Jim Galbally
jj, is that the same with the 3.0?
Old May 9, 2007 | 10:43 AM
Matt Baxter's Avatar
Matt Baxter
Back in black!
I use 0w 40 mobil 1
Old May 9, 2007 | 11:00 AM
JjCoDeX75's Avatar
JjCoDeX75
Hi Jim,
I believe that it is. I know of people that use the 0W40 etc etc in them, but most report an increase in oil consumption.
I know that mine is totally intolerant, and even if I use the wrong Castrol 10W60 oil rather than the genuine TWS oil (TWS standing for ten weight sixty!!!!!) it uses significantly more.
Castrol designed TWS for the M range from E36 onwards, so I reckon for the sake of a few quid, you cant go wrong really - it certainly wouldnt hurt from what I have read
Old May 9, 2007 | 11:24 AM
AlexF's Avatar
AlexF
TWS is only for certain M engines....not all the new ones use it. There was even a cut off date for the E39 M5....
Alex
Old May 9, 2007 | 06:53 PM
JjCoDeX75's Avatar
JjCoDeX75
Alex
This is true, but if you speak to BMW they will still recommend the TWS in the newer ones (I think to make even more money!) - I must admit that some BMWs are not consistent!
On the M5 forum I use, most seem to use the TWS, even the newer engine design.
As I understand it, they modified the ring design, dont know how or what they did, but it deffo worked!
Mine likes to use a rather frustrating 1litre per 800 miles. The newer ones report more like 1litre per 2k! I am very jealous!
JJ
Old May 9, 2007 | 06:56 PM
bud-weis's Avatar
bud-weis
Football Cwazy
This, according to OPIE
http://www.opieoils.co.uk/performanc...EDGE10W-60.pdf
from this list
http://www.opieoils.co.uk/performanc...s/castrol.aspx
Old May 9, 2007 | 07:40 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Mobil 1 0-40 goes in my M3, half a litre in 5000 miles
Old May 9, 2007 | 07:53 PM
JjCoDeX75's Avatar
JjCoDeX75
Have to say that Mobil 1 is not approved in any of the M cars.
Opie are quite good for oil prices, but you can buy the genuine TWS direct from Castrol direct - also free delivery as with Opie.
http://www.castrol.com/liveassets/bp...april_2007.pdf
I buy all mine from this.
JJ
Old May 9, 2007 | 08:05 PM
Si B's Avatar
Si B
Might not be recommended (for obvious reasons - they want you to buy their own over inflated oil) but works fine.
Plus it costs me £5 a litre. Can see no point spending more than is required. Mobil 1 is widely respected, and has worked fine in all of my cars - literally since I started driving.
I can get Castrol oils at similar prices, but I've stuck with what I know. The previous owner used the same oil, and I thought I'd stick with it as the car's still running, and not using any oil (well, 500ml in 5000 miles.)
Si
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
