Wiring up a rev counter???
Old May 7, 2007 | 08:18 PM
ShandzS1's Avatar
ShandzS1
Default Wiring up a rev counter???
I have fitted a xr3 rev-counter into my original clocks, but dont know how to wire it up, there are 3 wires,( blue, red, yellow) what wire reqires what etc? Power from coil? earth?
Old May 7, 2007 | 11:47 PM
SafeChav's Avatar
SafeChav
You've lost me there mate?
What rev counter have got and what have you fitted it into?
Old May 8, 2007 | 04:23 PM
ShandzS1's Avatar
ShandzS1
Sorry a see what ya mean, ive got a 1.3L mk3 escort, fitted a 1.9 cvh with 40`s, i didnt want to bolt a stupid rev counter on the dash, so i bought a set of clocks for a xr3 of e-bay. I plug`d them in and nothing worked. So i took the clocks apart and removed the rev counter from the xr3 clocks and took the time clock out of my 1.3L clocks and bolted in the rev counter. The 3 pins didnt line up with the printed circuit, so i was just going to run seperate wires to the rev counter(live, earth, etc). But i dont know what to connect to what? colours(blue, red yellow) which feed the rev counter.
EXAMPLE
RED to LIVE?
BLUE to EARTH?
YELLOW to -ve side of coil?
Is this correct?????
Old May 8, 2007 | 04:31 PM
SafeChav's Avatar
SafeChav
put the xr3 clocks back together and adjust the wiring in the plugs properly.
You'll need to run a feed into the car from the coil for the rev counter aswell
Old May 9, 2007 | 09:38 PM
ShandzS1's Avatar
ShandzS1
easier said than done.......lol
Old May 9, 2007 | 11:39 PM
SafeChav's Avatar
SafeChav
why
what have you done
Old May 10, 2007 | 08:14 PM
ShandzS1's Avatar
ShandzS1
Am a mechanic, not an auto electrician
Old May 10, 2007 | 11:21 PM
SafeChav's Avatar
SafeChav
i think you've taken my reply wrong.
When you say "easier said than done", what exactly are you talking about?
Old May 12, 2007 | 12:24 PM
ShandzS1's Avatar
ShandzS1
This one? are you on about the 2 plugs that go in to the back of the dash?? i have the plugs opf the xr3 wiring loom aswel and there are loads more wires, and nothing worked wen i pluged them in......
Old May 12, 2007 | 12:26 PM
SafeChav's Avatar
SafeChav
yea because the wiring configuration is different, and the extra wires are for the auxiliary warning system which you don't have.
Get a wiring diagram its fairly easy to do
Old May 13, 2007 | 07:13 PM
johnnysash's Avatar
johnnysash
hello mate,
do you still have the clocks and pugs from the xr3? for the purpose of tracing the wires put the xr3 clocks back together so you can follow the circuit board on the back of the clocks
if you trace the wires from the rev gauge back through the clocks and onto the the wires on the xr3 plugs. The wires on the plug will be easier to find what does what as, feed to the coil is normally (if not always) green earths are normally (if not always) brown lives can be any colour but reds favorite.
If you look at the circuit board on the back sometimes earths or lives are "common" there will be more than one thing wired off the circuit power from the same circuit earth from the same circuit etc.
A wiring diagram would help for the exact colours but hopefully what i told you helps!
good luck
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
TPM961
Jan 15, 2018 10:50 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
