help with wire rung block?? please
Old May 7, 2007 | 07:28 PM
garyrs's Avatar
garyrs
Default help with wire rung block?? please
hi to all , ok well here goes in jan-feb i was haveing trouble with leaking water ,so i took to bits and done the core plugs on the head exhaust side
then put back together an the was no leak from under car , but still loseing water, after a compresion test wich was all good, the was water in 3+4, so i took the head off , head gasket was broken in a few places but when i had a good look thismorning ,it has a wire rung block, however the was no wires in it????? can anny 1 give me anny info on this system were can i get some wires from? is it a standard size that is the same to all blocks or does it depend who done it? cheers Gary
_________________
Old May 7, 2007 | 09:17 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My block is the same, the headgasket lasted 3 years before it died.
The idea behind not using wire is that the fire rings on the gasket bite into the groove in the block to give a good seal.
Steve.
Old May 7, 2007 | 10:01 PM
bud-weis's Avatar
bud-weis
Football Cwazy
my understanding is that you either use wire, or don't use the block at all!
it does depend on who did the wire ringing, but it is a fairly simple process. you just need to get the correct sized wire ( mig wire i think ) and make sure it fits nice and doesn't protrude too high from the block, that said it needs to be done correctly and if you aren't confident you need someone to do it for you.
Old May 7, 2007 | 10:23 PM
garyrs's Avatar
garyrs
cheers for your help guys, i havent dealt with this b4 , trouble is the heads off so imobile , can anny 1 recomend some one in dorset area that can help,
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
