Putting a second rs lump in the back...
What is involved with putting an rs turbo engine in the back?
When its twin engine? How do the gears work?
Originally Posted by jonesymk2
the gear linkage wud probably b quite easy if u had a gearbox handy 2 look at and figure it all out
But it would be backwards in the back wouldn't it?
Its the clutch you have to worry about
surely u cud make up sum brackets and a pedal 2 use a cable and an extended cable 4 the rear gearbox aswell,well thats what i wud try anyway and try get hold of an old capri or escort mk2 cable with manual adjuster on it so cud fine tune the rear clutch then
My friend has done this conversion on his Orion using a modified ford pedal box
DixieTheKid
11
Jun 6, 2020 11:20 AM
Cossikev
Sep 13, 2015 02:00 PM
