Brand New JE Zetec Turbo Forged Pistons....SOLD
Old May 4, 2007 | 06:55 PM
craig rs's Avatar
craig rs
Default Brand New JE Zetec Turbo Forged Pistons....SOLD
Was going to be used for my zetec turbo project but are no longer needed spec as follows.....
Brand New
85mm in size
C/R of 9.0.1
Pin dia is 19.99mm
299 grams per piston
Come complete with new rings, split pins and connecting rods.
Want £260 posted
Old May 5, 2007 | 02:20 PM
turboloon's Avatar
turboloon
Default piston
wot engine size are they for ...?
Old May 5, 2007 | 03:20 PM
craig rs's Avatar
craig rs
2.0lt zetec
Old May 5, 2007 | 05:14 PM
RST_mark's Avatar
RST_mark
silvertop or blacktop? seems a fairly high cp ratio?
Old May 5, 2007 | 05:31 PM
davsmith64's Avatar
davsmith64
do they come with rods as said above.. regards dave
Old May 5, 2007 | 05:40 PM
craig rs's Avatar
craig rs
i brought them for silver top, dunno if they will fit black top or not, they come with everything in the pic, rods as in the rods that connect the piston to the con rod
Old May 5, 2007 | 05:41 PM
craig rs's Avatar
craig rs
the c/r is`nt that high if you concider that a the standard zetec pistons run at 10.0.1, these lower it to 9.0.1
Old May 7, 2007 | 09:12 AM
RSricRS's Avatar
RSricRS
Long live the ford RS'S
Just out of interest will these fit a 1600 cvh turbo (series 2)
Old May 7, 2007 | 10:47 AM
scotty86d's Avatar
scotty86d
std rs pistons are quite alot smaller than 85 mm arent they?
Old May 11, 2007 | 02:49 PM
smitsturbo's Avatar
smitsturbo
are these still availible?
Old Jan 7, 2014 | 07:50 PM
100792taz's Avatar
100792taz
Default pistons
hi have you still go the pistons thanks
Old Jan 7, 2014 | 08:19 PM
studabear's Avatar
studabear
They melted this summer.
Old Jan 7, 2014 | 08:35 PM
100792taz's Avatar
100792taz
oopps how did that happen
Old Jan 8, 2014 | 12:02 PM
studabear's Avatar
studabear
It was quite a hot summer.
robnock
21
May 13, 2019 05:29 PM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
