distributor
Old May 4, 2007 | 12:22 PM
RodgeRS_Turbo's Avatar
RodgeRS_Turbo
Default distributor
a few questions about this:
* when I had the dizzy stripped down, I could turn the arm no probs really freely, but when I built it back up, before I bolted it back onto the head I turned it but it was quite stiff - is this normal?
* is there meant to be an oil seal between the head/dizzy?
Old May 4, 2007 | 12:30 PM
SafeChav's Avatar
SafeChav
Did you fit new seals inside it?
Yes there is meant to be a large O-ring it'll piss oil out otherwise
Old May 4, 2007 | 01:07 PM
RodgeRS_Turbo
nah never fit new seals inside but now I will! does the seals come part of the head set? I know the "o" one will for the head to dizzy, but does the dizzy seals come with the head set? Cheers
RodgeRS_Turbo
also, is it meant to be quite stiff to turn once built back up?
Old May 4, 2007 | 02:41 PM
SafeChav's Avatar
SafeChav
Im not too sure what the seals look like as ive not stripped one myself but its unliekly it'll come in a headset.
Shouldnt be tight really you must of put something back in wrong
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 29, 2015 11:27 AM
dms04
Sep 11, 2015 01:57 PM
Anutternutter
Aug 21, 2015 06:07 PM
Sjieter
Aug 5, 2015 09:47 PM
