Fuel Pressure Regulator
Old May 2, 2007 | 11:04 PM
taz8520's Avatar
taz8520
Default Fuel Pressure Regulator
What does the screw on top of it do, would it make it rice ????
Old May 3, 2007 | 03:31 PM
taz8520's Avatar
taz8520
Hello???? 28994 registered users and noone answering
Old May 3, 2007 | 03:36 PM
M K's Avatar
M K
it will adjust the pressure itself,
, but it should only ever be set by your tuner or whoever sets up the car to the correct pressure, as wrong doing will cause damage
Old May 3, 2007 | 05:48 PM
As said used to fine tune pressure, on older non adjustable ones you could effect the same by squeezing in a vice to preload spring inside!!
Old May 4, 2007 | 12:05 AM
taz8520's Avatar
taz8520
So if it was set wrong could it make my car over fuel?????
Old May 4, 2007 | 12:55 AM
jon@work's Avatar
jon@work
yes, or underfuel
Old May 4, 2007 | 06:56 AM
Yes as delivery rate wil be different for same injector pulse.
If car chipped etc will have been checked for emissions anyway.
Old May 5, 2007 | 12:13 PM
taz8520's Avatar
taz8520
Well my cars done 25miles to a tenner so could it be something to do with the regulator ??
Old May 5, 2007 | 04:00 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Depends what engine, car, mods, driving style, load condition of car, so many variables
Bri.
Old May 5, 2007 | 04:36 PM
Christ that's thirsty, unless you overtook SCHUMACHER at the time!!
What spec is it etc, what is the CO reading ?
Old May 5, 2007 | 04:58 PM
25 mile's to a tenner
i'd be looking for leak's
Old May 6, 2007 | 12:05 AM
taz8520's Avatar
taz8520
Cars xr2i 1.6 cvh standard, the CO reading was high when ran on dad's machine so he adjusted some little screw on the throttle body said it should be little better , its only been bad the last few day, usually i get about 40/50 mile on tenners petrol, i not even been ragging it lately
Old May 6, 2007 | 09:44 AM
Looking for leaks!!, I would be looking for the next PETROL, STATION!!!!
Old May 6, 2007 | 11:11 AM
Old May 6, 2007 | 11:27 PM
taz8520's Avatar
taz8520
Seems ok now got about 45miles on Ł8/9 worth petrol and that was raggit a little
Old May 7, 2007 | 10:52 PM
Stu @ M Developments's Avatar
PassionFords Creator
Screw on the throttle body doesnt affect the CO, its teh idle bypass screw.
Old May 7, 2007 | 11:44 PM
SafeChav's Avatar
SafeChav
Originally Posted by Stu @ M Developments
Screw on the throttle body doesnt affect the CO, its the idle bypass screw.
and to add it wont change the idle if you turn it anyway
timsrs
Nov 13, 2018 11:48 AM
SMILER258
Sep 28, 2015 09:04 AM
Dubs44
Sep 19, 2015 06:31 AM
