bd14s
Old May 1, 2007 | 08:33 PM
Smoker's Avatar
Smoker
Default bd14s
i have recently put some cams into my 4x4 had it all set up but the car does not have a stable idle. has any one with bd14s have this same issue or is it just normal for them to make the engine to behave like this?
Old May 1, 2007 | 08:49 PM
Depends what you mean by "all set up", if it was just the cams were put in, you will have a disasterous idle until idle fuelling sorted, as cams a re a hell of a lot hairier.
Old May 1, 2007 | 08:52 PM
rapidcossie's Avatar
rapidcossie
Up the idle slighty and it should help
my car idles at 1100 and is quite smooth while using cams with more lift and duration that 14's.
Old May 5, 2007 | 07:19 PM
saphcossie427's Avatar
saphcossie427
Default bd14's
My 4x4 saph runs 14's with verniers and runs pretty smooth on idle (850rpm)
but they were "dialled in" by the guy who mapped it, very slightly lumpy but
hardly noticable
Old May 6, 2007 | 05:05 PM
col cos1's Avatar
col cos1
my bd14`s make my car tick over lumpy as hell,but i love it that way it sounds great,but the idle only dips and rises ever so slightly
Toe Knee
Aug 23, 2015 08:31 AM
abdr500
17
Aug 9, 2006 02:20 PM
abdr500
Aug 7, 2006 12:18 PM
CossieRich
15
Jul 27, 2006 07:30 PM
cossie350
Jun 2, 2005 07:02 PM
