How much zetec standard con rods can take power?
Old May 1, 2007 | 08:04 PM
Juissi's Avatar
Juissi
Default How much zetec standard con rods can take power?
Engine is 1,8 ZVH turbo!
Old May 1, 2007 | 10:21 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Some people have said 270 to 300 but its the boost that kills them so i've been told
Old May 2, 2007 | 03:19 PM
JesseT's Avatar
JesseT
Ilpo is running ~330hp in his 1.8ZVH and hasn't had any trouble. Not a very good benchmark though knowing the way he drives
Old May 2, 2007 | 03:32 PM
bassboy's Avatar
bassboy
IMO i think its more det that will cause a rod and piston to go....300hp is generally the safe mark these days much beyond this and the pressure on the rods with the explosion will be enough to bend them...
reason i say det can kill the rods is coz of the violent explosion causing nasty vibrations
anything over 300hp i would say steel rods IMO...especially as they are so cheap!
bassboy
Old May 2, 2007 | 05:37 PM
Juissi's Avatar
Juissi
What kind of boost and what kind of compresion ratio you have been use? can they take 1.5bar (21psi) and do they need better con rod bolts like Arp?
Old May 2, 2007 | 07:08 PM
JesseT's Avatar
JesseT
The bolts have not much to do with power or boost, mostly just max RPM. And turbo ZVH is not known for being a very rev happy engine. On the other hand, for myself, if I didn't use at least new bolts, I would worry and regret each day that I had saved the price of 8 bolts.
As to the con rods, it's RPM, CR and det that also play important role in the con rod killing game. If they are reasonable, then 1.5bar doesn't sound much at all.
Old May 2, 2007 | 07:28 PM
Juissi's Avatar
Juissi
Jeah! of course i use the new bolts, but the arp bolts cost over 100€ and the original ones i have on my garage. i put the wiseco pistons and on the cr is 7,5:1 so i thing it is good. The Eagle con rods costs me over 500€ and that makes me thing if the standard one will hold up. sorry about the bad english!
Old May 3, 2007 | 04:18 AM
JesseT's Avatar
JesseT
Why do the eagle rods cost you over 500e when they cost everybody else max 300e? Nevertheless, if you run a CR as low as 7.5, I don't think you have a problem.
Old May 24, 2007 | 10:09 AM
Ilpo's Avatar
Ilpo
Look who's talking!
Anyway, the base engine on my car has done some 20 000 miles with different levels of power. First running 250 bhp and gradually improving to the current 300+ tune. It has also done numerous top speed events and track days also in current spec. Does it proof anything? It's hard to know since every engine is a unique item and everyone drives and tunes them diffrently.
James Porter
Oct 28, 2015 12:17 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
track.focus'd
Aug 12, 2015 05:53 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
